Dear Users,
We are planning for the next release with "Advanced Customizations for Requester Portal and Enhancements in Problem". Below is brief note on the same :
You can now customize the requester portal with advanced options like
panels, buttons, lists, snippets, etc over pre-defined or custom
templates. To access these customizations, go to Setup >> General Settings >> Requester Portal >> Requester Portal Customization and click Configure on the ADVANCED card.
Note: The customization options that were previously available will now be identified as Basic Customization. To access it, go to Setup >> General Settings >> Requester Portal >> Requester Portal Customization and click Configure on the BASIC card.
Problem Module as an Add-on
Problem Module is now available as an add-on for Standard and Professional editions.
Problem Enhancements
Configure tasks within problem templates. When creating a problem, technicians can choose the tasks to be triggered on problem creation.
When changing the template associated with an existing problem, the technician can choose to delete or retain the tasks associated with the previous template.
You can now forward/reply to conversations from within the problem details page. You can also save drafts which will be listed in the right panel of the problem details page.
Under the history tab of the problem details page, you can search for a particular activity or sort the activities based on the time, users involved, and the type of action.
We shall keep this post updated, once it is released.
Please write to us your feedback and queries.
Thanks & Regards,
Saravana Balaji
ServiceDesk Plus Cloud
