Upcoming Release: Enhancements for Problem, Change, Asset and Dashboards
Dear Users,
We are ready to unwrap the upcoming enhancements for Problem, Change, Asset and Dashboards. Below are the details,
Problem Form Rules
- Introducing Problem Form Rules to help you create rules based on custom criteria to perform various actions such as Hide Fields, Show Fields, or Mandate Fields on problems.
- These rules can be applied based on the template selected. Users can also customize when to execute rules, based on various form events.
- Problem Form Rules can be created under Setup > Templates & Forms > Form Rules > Problem Form Rules.
- To learn more, click here.
Note: Form Rules cannot be executed upon spot editing of problem fields in the details page. However, SDAdmins have the option to disable spot edit in the problems details page using Advanced Portal Settings.
New Asset Widgets for Dashboards
- Added Product Types by Sites and Product by Sites widgets for dashboards. These widgets plot bubble pie charts to visualize the distribution of assets across sites along with asset states.
- You can customize the widgets by clicking the filters icon on the top-right corner of the widget and selecting the parameters as required.
Enhancements
Tabular Reports Enhancements
- Tabular report wizard UI is enhanced for better user experience. Users can search and choose columns under Select columns to display and Advanced Filter sections.
- Users can now generate reports based on Software Installations and Software License Users.
- Users can select second level fields while selecting columns to display in custom reports and in advanced filters. The following tabular reports contain second level fields.
- Software Installations
- Software License Users
- Virtual Machines
- Virtual Hosts
- Asset State History
- Mobile Devices
- CMDB reports
- Custom Module reports
- Consumable reports and its children
- Releases
Support for requesters to create change requests
Change Form Rules Enhancement
- You can now configure change form rules to be applied for Requesters or Technicians. To do this, go to Admin > Templates & Forms > Form Rules > Change Form Rules and select your preferred option using the Rule applies for field.
Dashboard Filter Enhancement
- The Select Group drop-down now lists groups as sub-lists of sites.
- You can now choose All Groups and Not in any group options for any site from the Select Group drop-down.
- Added an option to include referred sites.
- The tooltip that appears when hovering over the filter drop-down is redesigned to include detailed information on the selected sites and groups.
Stay tuned for more updates!!! We will update once these enhancements are untied in live.
Kindly share your thoughts/queries/feedback .
Thanks & Regards,
Sri"Ram" K S
New to ADSelfService Plus?
